Beefing up my winshield lights?
Old 03-23-2012 | 09:19 PM
Delux2769's Avatar
Lol, be sure to unplug them before putting in the bulb or cleaning. And point away from you when turning on again.
Old 03-24-2012 | 01:55 AM
MrCourtney's Avatar
Originally Posted by iheartmopar
This may be a stupid question, but I've got two 55 watt lights on my windshield and I want to beef them up to 100 watts or even 150. Can I just replace the bulb inside with a higher wattage in the light and put a stronger fuse in?? Also I don't want to buy a whole different light bc I love the way mine look.
Thanks team!
I wouldn't. The housing is designed to handle the heat from the 55w. You'll need to swap almost everything to make sure you have something that won't burn or blow up on you.
Not a good idea on the trail at night.
You want more light - look at the LED stuff out there. Brighter and lower amp draw.
You'll get used to the look.
Old 03-24-2012 | 08:48 AM
iheartmopar's Avatar
Again, I don't have a shit load of money to spend.
Old 03-24-2012 | 08:49 AM
Haha good idea! I'll try to remember that.
Old 03-25-2012 | 02:07 AM
JK-Ford's Avatar
Always try plugging in a better bulb, or cleaning the inside of the light to a more mirrored finish.
Wires and fuses are same from 55w to the 100w sets.
It is quite possible that the wiring may be sufficent to handle the additional load. One would have to visually varify the conductor size to be certain. However the fuse rating is a completely different story. Or atleast it should be.
Old 03-25-2012 | 02:11 AM
JK-Ford's Avatar
I'll give that a try. Worst case scenario I blow up a light. In my face.
Chances of the light blowing up in your face. 1 - 1,000,000.
Chances of burning you Jeep to the ground. 1 - 10.
Old 03-25-2012 | 02:15 AM
Kojack's Avatar
Get a set of 4300k 55w hid bulbs from vvme.com. I have them in my hella 500 housings and they are bright. Much brighter than my 130w halogen bulbs I had in. Cost is about 70 bucks.
