Bedlining rims
Sure! I really like the look of them from the pics that I've seen in the forum. I think they'd be killer on my white Jk. I would purchase black wheels outright......but I have twins coming any day now and this should hold me over until money is a bit more plentiful (like in 18 years lol).
I am right there with you on cost of toys vs. cost of family! There are many threads here from folks who painted, powder coated and lined there wheels. Congrats on the addtions to your home!!
Congrats for the addition to the family!
Id say 3 coats of bedliner would do the trick. The first coat looks to be uneven then the second coat gets better. The third coat eliminates any uneven spots. Youve probably noticed this from looking at pics of write-ups though.
Simple to Do.....
It is really easy and had to goof up....
First I block my wheels on the Jeep (so it did not roll off the floor jack, and removed two rear. After I completed the two, I replaced them onto the Jeep and removed the front 2 & Spare.
I used the blue painters tape to tape off the tire around the wheel lip. I removed the center Jeep hub (as I kept them Chrome). I placed the wheel on a flattened cardboard box to absorb all the liquid. I taped the valve stem. Sanded the wheel and then I degreased the wheel (both sides). I had to use a portable heater as they suggest over 60 degrees. I dried the wheels and I sprayed 2-coats of the Dupli-Color Bed linner. (Allow 5-10 minutes between coats) DON'T OVERSPRAY. Once dry (very quickly) I then re-wiped the inside of the wheel and sprayed the backside with Rust-Oleum Flat Black. (DO NOT use the bedlinner on the inside as it will hold dirt & mud. I also had to paint (Flat black carefully on the Front brake metal work otherwise the silver showed.
All five wheels painted and on the Jeep within 2-hours. I used 2-can of degreaser and 1-1/2 cans of the Dupli-Color bedliner.
Once all the wheels were on the Jeep, I torqued all the lug nuts and THEN put on the center Jeep cap, knowing that the wheel was finished.
Looks GREAT..... could not be any happier....
HAPPY PAINTING.......
