Bedliner
More expensive in FL. I had mine done today with Line-x. It was 1000 if they strip the interior or 750 if I stripped. Of course I stripped. But I think they are not as careful about taping threads when they know they aren't putting it back together. I have started re-assembly (2 hours into it) and I'm using a razor knife to remove product from bolt threads to get it back together. The coating is about 1/8" thick, and well, except for re-assembly, I love it. Seems very tough and it has a lifetime nationwide warrantee. I think I'm good. Should finish up assembly tomorrow.
You can get herculiner from your local northern tool or I think Home Depot has it. It's 100 bucks comes with a roller and another back up roller. It can be brushed or rolled and looks about the same as any other bedliner. Really holds up with the elements.
I've heard more bad then good about herculiner.
I just did mine a couple weeks ago with the Rustoleum it was around $60 for the 1 gallon bucket and another $10 for the roller kit and it serves the purpose that I want. If I have to do some touch up every so often I'm fine with that. Plus you can just buy a spray can of it and do some touch up with that.
You will get the best quality results out of a two part bedliner. The ones that are ready to roll with out mixing a hardener won't hold up as well. I have used the Herculiner and Rustoleum roll on ones in the past. with less than desirable results. The Raptor liner that I just used on my two door gave much better results.
BedLiner
I'm wanting to bedline the interior of my Jeep but I was wondering what's the best kind to use? I've seen herculiner, raptor, and others but I want others' opinions. I would like to save money and do it myself but I don't have a spray gun so does anyone know of places that do it for you? I live in the OKC area.
Trying to keep this project under $300
Thanks!
Thanks!
