Bead locks
#62
both sets of my BL's came with the stems already installed. Straight stems on the Raceline's. Angled stems on the TR's. I'd be surprised if they didn't already come with them installed or at least loose packaged along with the ring bolts....
#63
Would be nice. I just watched one of the videos by method installing their beadlocks and they were not installed already. Maybe they did this to show how to do it for others watching it with different wheels, I don't know.
#64
Here they are - $60 for 5
http://www.ebay.com/itm/Jeep-TPMS-Ti...-/121049816777
#65
The TPMS is built into valve stems so I installed factor mopar ones when I got my methods. Bought 5 on eBay for pretty cheap (don't remember the price). MR105’s do not come with them installed so you'll need to get some before installing your tires. I actually mounted a tire and forgot to install the valve stem first - boy was I pissed. Had to unmount it
Found these on amazon really quick. Seem to work with the 2013 JK, but ill search around more.
http://www.amazon.com/Chrysler-Dodge...5R09MV6AEFZC8Q
#66
Yup they are the same item numbers. I guess I can pick these up to use the function the Jeep has on it already lol. I should of kept my originals, lessons learned.
Well to help save on the cost and give me more knowledge of my bead locks I will be doing the install. Im just hoping my ARB twin compressor will do the job in setting the bead. If not I can throw the Jeep on stands and use the wife's car to take them to the local shop just for that.
Ordered my TPMS sensors
Valve stem install tool
Valve core tool
I already have a torque wrench, but may look into a different one.
Valve core tool
#67
It should do fine I think. Just put it on a 5 file gallon bucket with the bead lock facing up. Gravity should help force the inner bead down.
Be sure to use anti-seize! I didn't torque it down as tight as the instructions said - think I stopped at 20lbs.
#68
Yeah I'll pick up some of that stuff as well. Did you or anyone have to use ring spacers with these wheels?
#70
