BB install help!!!
Old 01-19-2011, 12:23 PM
medic_23387's Avatar
Originally Posted by _J__C_
.prothane.com/whatsnew.php
If you look at the picture on this page, the two spacers in the front(middle) go up front. The two on the outside go in the rear. The rubber "spacer/isolator" or whatever it's called that is above the factory springs goes under the spacer, and against the spring.
Sweet that helps a lot. All I need now is to figure these bump stops out.
Old 01-19-2011, 12:40 PM
Are they upper? It does not look like the old ones could insert into those.
Old 01-19-2011, 01:58 PM
_J__C_'s Avatar
They look like it. Maybe you pull the factory ones out and those in place. You may want to look a shock extenders or new shocks after the 2" lift.
Old 01-19-2011, 03:15 PM
Yeah I'm going to do a full suspension lift later on
Old 01-19-2011, 06:38 PM
ALs07's Avatar
I have the same kit. Check out the Black Diamond lift instructions, it's what I used. Use some grease on the new bump stops. You do not reuse the original ones.
Old 01-19-2011, 09:15 PM
thanks a lot
Quick Reply: BB install help!!!
