BB install
I have read the write up on installing a Budget boost lift. My is has anyone done without jackstands? I have a floor jack for the axle lowering but wondering if I could use the jack that came with the Jeep for lifting the Jeep?
you need to hold up the entire front(or rear) of the jeep at one time. jackstands are the easiest way to go about this. once the front(or rear) is up you need to lower the axle in order to get the springs to droop.
i wouldnt rely on the stock sizzor jack to hold up half of the jeep while i am trying to pry out or stuff back in the springs.
Thanks for the input. I agree safety is a bigger factor. It isn't the money for the jackstands. I just don't know if I will ever use them again. But I will be buying them before I do the install. I hope it is as easy as it looks to do.
you will use them again,,, or just goi and borrow some,,i dont see how to doi without the stands
dont forget to stuff your tires under the jeep for safety
Also, it is a good safety tip to stuff your tires under you jeep. It is better to be 10" thick than dead.
JK-Forum Founder
Actually, spend 25-30 bucks at Harbor Freight or Sears and get the 6 ton stands. It is not the 6 tons you need to worry about but the fact that they adjust to 24". Once you get lifted and bigger tires the 3 ton ones are too short.
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
I actually just got done installing a Teraflex BB kit. You will need the jackstands.
The only complaint I have about the kit are the instructions (they suck).
Definitely get jack stands, though, it's a must.
I admit that I install the BB's with only an 8-ton floor jack. I disconnect the shocks and sway bar links only and leave the track bars attached. On the front axle, make sure to do the driver's side first. A 2x4", a pickle fork, and/or a prybar will be your best friends, especially if you are not using spring compressors.
