battery replacement?
Anyone replaced the stock battery after installing a winch? ...or maybe even set up dual batteries? If so how did you do it and what did you use?
http://www.quadratec.com/products/pr...03+02&h=&spg=t
I don't know the part number off hand. I bought it off Quadratec. I think the red top is one standard size. The Yellow top is a deep cycle battery and the blue top is a marine battery that can also be used in a 4x4. Here is the link.
The red top should do just fine with the stock alternator. The yellow is a deeper cycle that would also be fine, but probably not needed with the 160 Amp. alternator. JMO.
