View Poll Results: Which aftermarket battery do you have?
Odyssey
14
5.76%
Optima Red Top
39
16.05%
Optima Yellow/Blue Top
139
57.20%
Other
51
20.99%
Voters: 243. You may not vote on this poll
Which battery
Old 08-17-2008 | 05:58 PM
  #21
Offroad's Avatar
Exide Orbital blue top
Old 08-17-2008 | 08:19 PM
  #22
rickl's Avatar
Exide "purple haze"(yellow top clone)
as a long time heavy truck mechanic have seen full deep cycle style(ie blue top)not get along very well with high amp alternators,not sure if that stands true with all these gel cell types but that is why I went to a semi-deep cycle or hybrid style battery over blue top style
only bought"knock off"because no one had yellow tops in stock weekend I installed winch
Old 08-18-2008 | 12:05 AM
  #23
gonetoshoot's Avatar
Optima yellow top
Used em for years flawlessly
Old 08-18-2008 | 10:46 AM
  #24
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
Optima Yellow
Old 01-05-2009 | 08:30 AM
  #25
HG07JKRubi's Avatar
So for a daily driver with occasional winch and air compressor use a Yellow Top is recommended over a Red Top? Just trying to get educated here...Or will either one do the job?
I think my stock battery is failing as the battery light came on today (and usually does during winching, airing up tires). But today I could not restart the engine which is a first in this JK.
Old 05-27-2009 | 05:00 AM
  #26
Paul R's Avatar
Reviving an old thread, but I figure more folks are approaching the need to replace the stock battery and I wanted to discuss some info I gained researching batteries...
My stock battery gave up the ship yesterday and I had to jump the Jeep to get it started. It had been sounding weak starting up for a few days, so I knew it was coming and had thrown my jumper cables in the back just in case. If I drove for a while then started it within an hour or two thereafter, it started fine, but if it sat for more than a few hours (like overnight) it would crank very slowly. This was the sign that it was the battery not holding a charge and not a problem with the alternator.
I did some research and narrowed it down to a choice between the Optima Yellow Top and the Sears DieHard Platinum. Both are AGM gelcell batteries, which was important to me as I have had an acid leak in the engine compartment in a past vehicle and didn't want to go through that again. I went with the DieHard for the following reasons:
1) Saw some posts on other JK forums where Optimas were not lasting too long. I know that on this forum, most folks say they are lasting fine, but I did see several posts stating that they died within a year. For the Diehard Platinum, I did not see a single comment stating they had died early. There was a lot of speculation that the Optima did not like the high voltage coming from the JK alternator (between 14.5 - 15.0 v). Strike One.
2) One thing that I thought was interesting is that the Optima website, on their vehicle specific lookup for battery type, has the following comment for the JK, "Customer must know: Use Yellow Top Only". I am guessing that the Red Top cannot handle the voltage, or else they have found that the JKs are modified frequently and thus the electrical load can be high enough that a Deep Cycle battery is required. I do have a winch, but it is used so infrequently (maybe once or twice a year), that I would prefer not go deep cycle. Deep Cycle batteries are meant to be drawn way down and charged back up. The Red Top is designed for shallow power draws and being kept near full charge (as in a daily driver duty). My usual driving habits indicate that a starter battery rather than a deep cycle would work better for me. But, Optima says to only use the Yellow top. The contradiction worried me a bit...Strike Two.
3) Optima website lists the yellowtop warranty as 1 year full replacement. Sears Platinum is 4 years full replacement, 100 month prorated replacement. Strike Three against Optima.
They both cost about the same, so price was not a differentiator.
I got a DieHard Platinum P1. I know that several folks state to get a P4, but the P1 and the P4 are basically the same battery. The only difference is that the P4 has both top and side terminals, where the P1 has only the top terminals. I don't need the side terminals, so I went P1.
I will let you know how if it has any problems or dies early.
Old 05-27-2009 | 05:19 AM
  #27
Jsr's Avatar
Jsr
Paul,
Great evaluation...I too am going for with the Sears DieHard for all of the same reasons!
Old 05-27-2009 | 06:11 AM
  #28
TiredPete's Avatar
I went with the DieHard Platinum P4 about 2 weeks ago. So far so good. Reviews and warranty difference sold me.
Old 05-27-2009 | 06:51 AM
  #29
jeepsanddrums's Avatar
I heard this as well. I wish I knew if it was true. I was going to get yellow tops for my dual battery setup.
Old 05-27-2009 | 07:56 AM
  #30
bly109's Avatar
I ended up getting a 31 series, deka intimidator. I had to do some creative cutting to make it fit, but it works great.
