Batteries what type to use for winching
That's a bit of a task you're asking. Surely an Optima will be better than the stock battery, but you must remember that normally when you're winching you are most likely at an idle. Although a battery such as an Optima might help, at idle, your alternator is not at peak performance, whether you have a 140 amp or 160, so it is not only providing power to your electrical system components, but also providing power for your battery for charging. Perhaps next time you're winching, try upping your RPM's a bit. If you're winching with just the battery, there are very few batteries that can withstand the rigors of maintaining enough power for winching and also provide power needed for other components. It's all a matter of E/I/R.
The good thing about a super battery is that it will provide you with power above and beyond a stock battery and recharge more quickly and more times after a hard tasking. What size alternator do you currently have?
The wifes 07JK has a 160 amp, however I've heard that they've begun to put in 140's in later years.
As for the power windows, I would have to believe your headlights are not going dim while running, but if that is the case, it appears you're battery may be ready to give up the ghost, or your alternator/regulator is not working as designed. Have the electrical system checked out under load.
At any rate, an Optima for a replacement is a good choice.
Manual windows and locks dont have that problem
so can you pick one of these up at a local auto parts store, or do you have to order them? straight from Optima they are $215....
can anyone with one of these tell me if it stops the head lights from dimming every time you roll your windows up and down, haha... mine dims if i lock my doors or roll the windows up or down:(
I was told 169 amp alternator for the JK
optima are all good
i used an opttima in my dodge for plowing but have upgraded to a dual battery setup because i hate the lights dimming also. id go with the red top it worked great in my dodge with an 8.5 boss v plow and that must draw just as much juice as winch
http://www.jeephorizons.com/tech/200...ited_spec.html
Note the diference between the 2007 and the 2009 alternator.
I'll add this is a very good site for most of the specs you are looking for.
Sorry, The link above is for the 2007 JK only.
This is the link for the 2009 and above.
http://www.jeephorizons.com/tech/index_reference.html
Again on this link note the diference between the 07 and 09 JK.
