Ball Joints job and additonal WHAT?
Old 03-04-2016 | 07:54 AM
  #21
Chuck-The-Ripper's Avatar
If he is paying to have a mobile welder come do it than they aren't such a cheap option
Old 03-04-2016 | 02:20 PM
  #22
Unlimited_Fun's Avatar
Roger that. I think I'm going to just pass on the gussets for now folks.
I see that OMIX-ADA has a 5 year warranty on their bearing hubs, anyone know about them? Where they are made etc?
Old 03-04-2016 | 02:24 PM
  #23
jedg's Avatar
Vet Army
Same place as the Timkins... they are ILJIN products... as ronjenx said earlier. The only real difference I've seen in them is that some have a longer ABS wire than others. Not sure which part number gets you the longer wire though.
Old 03-05-2016 | 10:57 AM
  #24
Thanks for all the opinions - I've decided to NOT do the gussets due to cost, labor and coordinated efforts. I'm also not going to a BB kit.
This is the PARTS LIST that I'm considering:
1) Synergy Ball Joints - I already own these
2) 5-760X U-Joints bills as heavy duty, fits Dana 30
3) Timken HA590242 Wheel Bearing and Hub Assembly = 1yr warranty @ $89.21 ea
or Omix-Ada Replacement Front Hub & Bearing Assembly = 5yr warranty @ $124.99 ea
4) 80w - 90w Synthetic Gear Oil fr & rr
Also one Ball Joint kit rental for ball and u-joints, 36mm socket, grease and grease gun
Old 03-05-2016 | 11:40 AM
  #25
jedg's Avatar
Vet Army
I'd go with the cheaper wheel bearing assemblies. They are the same maker. I've got 55,000 miles on mine (I think I purchased Timken) with 35s and wheel in the moderate range (3-4 rating on places where 6 is the toughest- still subjective) and DD it. No issues.
If you don't have one, try to get access to a 1/2" impact wrench. That will help a bunch with getting the ball joints out and tack in.
Old 03-05-2016 | 11:55 AM
  #26
Thanks for that. I've driven less that 2k in the 26 months I've owned so I doubt I'll really wear out the parts, I just see a lot of logging road.
I do have an impact wrench and long wrench bars, cheaters, torque wrench etc. I already started the P-Blaster on everything.
Old 03-05-2016 | 11:22 PM
  #27
dahreno's Avatar
You have posted this question on every site there is, got your answer yet ? lol !
Old 03-06-2016 | 12:30 PM
  #28
Just about . . . and I'll post any more project questions like this across every site in order to maximize good advice and best practices born from a broad range of experience. The next time some schmuck like me has a question about parts and labor along these lines, hopefully they'll be able to get the bottom line from the threads no matter what site they peruse.
Old 03-06-2016 | 09:01 PM
  #29
Slowpony46's Avatar
The tear down for ball joints isn't really the same as for axles and a hub. Yes you take the hub and axle out to do the ball joints, but that's the easy part. Removing the knuckle and pressing the joints out/in is most of the work. So honestly if you want to save money and not replace perfectly good hubs or u-joints, later on down the road of you need a hub it isn't that much work.
Jack the vehicle up and grab the tire at 12 and 6 and try to wobble it. Play here would be the hub or balljoints, it takes a lot less force to move a bad hub than a bad joint typically. You can also check for play between 3 and 9 and between like 11;30 and 4:30. This way you'll be checking tie rod ends and the hub at a different angle. If no play, and no bearing noise, chances are the hub is fine. When you take the axle out feel for play in the u-joint and look for rust streaking around the bearing caps, these indicate a bad joint.
But if you really want to replace these parts either way just to start off new, I can understand that. The hub will add zero extra work obviously, and the u joint adds a bit but they aren't too bad to change. I daily drove a lifted Ram (front Dana 44) on 37s for years when I was young, and changed the u-joints probably 6 times.
Old 03-07-2016 | 12:02 PM
  #30
Thanks for that, the rust idea hasn't occurred to me. The voice of experience win again.
I was also curious about checking the tie rod ends properly too, but I'm still not sure how much wiggle wiggle is too much wiggle wiggle.
I'm pretty sure I saw a write up about checking that, I'll try to find it again.
