Ball Joints job and additonal WHAT?
Last year or so I got some Synergy Ball Joints from a neighbor and thinking of putting them on this Spring.
As long as I'm pulling off the wheels and brake assemblies, I wonder what else would be hella convenient to do while it's already tore down that far?
Grease the wheel bearings \ axles?
Thoughts or suggestions?
Thx
Thx
Thx
Thx
Check the torque on all the suspension parts (track bar, drag link, tie rod, control arms)
Easiest way (for a home mechanic) to get the ball joints out/in is to rent a ball joint press kit from OReilly Automotive (or you choice of auto parts store) and have a good 1/2" impact wrench on hand. When using the press, unhook the shocks and droop the side you're working on as far down as you can get it. This will keep the press from hitting the coil spring.
If you plan on running large tires (or already are), this is a good time to weld on some C gussets while the ball joints are out.
I did mine last year. If you scroll down in this album, I describe how I did it in the image captions ...
https://m.facebook.com/markddoiron/a...1858211877885/
The brakes on the front are too new too new to replace, I'm running 35's all around.
I already own these - Synergy Manufacturing 8009-12 Jeep JK/WJ Dana 30/44 HD Ball Joint Set
I see this on Amazon = Timken HA590242 Wheel Bearing and Hub Assembly
Are there some other brand and prices that are better in some way?
And for U-Joints: MOPAR vs AC DELCO vs SPICER . . . same question, is the mopar price worth the extra cost, is warranty a consideration?
What about the Synergy Manufacturing 8012-02 Jeep JK Front Dana 30/44 Inner C Gusset ? Keep in mind that I'm a camper, not a crawler.
Thx for the info!
Thx for the info!
Thx for the info!
Thx for the info!
That said, I don't have much specific experience with those brands/parts on jeeps but I have done a ton of hubs and u-joints (I work on trucks and construction equipment, from f-150s to freightliners) and I have never had any problem with Timken hubs. I typically like OEM when possible but I've used more than a few Timken hubs with no issue. For u-joints I like Spicer. The Mopar one may well be made by spicer, but if it is cheaper to buy spicer go that route, you won't find a better OEM style joint than them, and for what it's worth they made your entire axle assembly anyway.
From that, I can only assume all the JK unit bearing hubs come from ILJIN.
My Wrangler has 89k, I doubt these things have been done before. I hear odd knocking\knuckling that I can also feel in certain turns etc, a sense that something is wrong but I can't identify and that mechanics haven't determined.
I don't weld, and the guy I want to pay to help me get this done and done doesn't either.
Renting the additional tools from the parts store is cool, but idk about trying to get welding done so that might not happen.
I see a lot of logging roads, it just seems like the ball joints, bearings and u-joints would be the things to do.
Is there a wiggle wiggle wiggle test I should rely on?
My Wrangler has 89k, I doubt these things have been done before. I hear odd knocking\knuckling that I can also feel in certain turns etc, a sense that something is wrong but I can't identify and that mechanics haven't determined. I don't weld, and the guy I want to pay to help me get this done and done doesn't either. Renting the additional tools from the parts store is cool, but idk about trying to get welding done so that might not happen. I see a lot of logging roads, it just seems like the ball joints, bearings and u-joints would be the things to do. Is there a wiggle wiggle wiggle test I should rely on?
