Ball Joints bad after 1500 miles?!
Old 03-30-2015 | 12:35 PM
  #31
DJ1's Avatar
DJ1
Former Member
Originally Posted by Derek1976
Well this sucks, i just got my synergy ball joints from Northridge4x4 last week. What would you guys recommend doing, i haven't installed them yet. Should i take my chance and put them in? try sendIng them back to Northridge? (Will they take them back?)
Are you installing them yourself? If so, I'd probably roll the dice. As much as I like Northridge, if you return them their restocking charge sucks balls.
If you are paying to get them installed, that's a tough call.
Are you still running stock tires/wheels? You'll probably be ok if you still are.
Old 03-30-2015 | 12:50 PM
  #32
ronjenx's Avatar
Well this sucks, i just got my synergy ball joints from Northridge4x4 last week. What would you guys recommend doing, i haven't installed them yet. Should i take my chance and put them in? try sendIng them back to Northridge? (Will they take them back?) Another thing i noticed they are knurled. I think it was the teraflex video they advised against using knurled unless you had a sloppy fit or if knurled was previously used.
I have almost 20,000 miles on mine. They are still tight. I grease them at each tire rotation @ 3,000 miles.
Old 03-30-2015 | 01:35 PM
  #33
Derek1976's Avatar
Yep I'll be doing the install myself, i figured there would be a restocking charge as well as he hasle of shipping them back. Ill probably just put them in and see. I'm on stock rims and tires now but am picking up a set or 33's off my buddy at work in a few weeks.
Old 03-30-2015 | 01:39 PM
  #34
Kojack's Avatar
A lot of folks misunderstand what lifetime warranty legally means: Nothing. The term you want is unlimited warranty. That has a legal definition. Lifetime warranty may mean for the life of the product. Brake pads are warranted against defects until they are worn down. You don't walk into O'Reilly's and get a new set free just because they were lifetime warrantied (as I witnessed just a few months ago when one misinformed consumer learned the truth). Limited and Unlimited Warranty: These terms have legal definitions. Everything else is marketing speak...
Lifetimewarrantymyths...Your lifetime warranty might not be worth what you think
Well I guess I got a great Napa dealer. I get worn parts replaced.
Old 03-30-2015 | 02:06 PM
  #35
Tim08JK's Avatar
Update: Took it to a different shop during lunch to have the ball joints checked and he said they are perfectly fine. He referred me to another shop to have it aligned, since he didn't have an alignment rack. I'm also going to have them check the ball joints, as well.
Old 03-30-2015 | 02:22 PM
  #36
Derek1976's Avatar
I'll do the same. I am going to be replacing the drag link and tie rod as well and they also have grease zerks so i will be under there with the grease gun anyways.
Old 03-30-2015 | 02:31 PM
  #37
JeepersDigest's Avatar
Greasable ball joints make perfect sense when one is going to redo what someone else didn't in the first place. I'm use to the greasable kind from old school days. Thus new greasable Moog Ball joints are on our list.. can't afford the Rare Part's Version at $400.00+ a set.. and only 1 year warranty & made in the USA.
Old 03-30-2015 | 02:34 PM
  #38
nthinuf's Avatar
Originally Posted by Tim08JK
So, they took me out to the garage floor and showed me...yeah they are definitely bad.
What did the first shop show you? The second shop is not seeing whatever it was that 'you' saw at the first shop? Or the second shop is saying that whatever it is you saw is not a failed/failing balljoint? You just had it aligned, what is the second shop thinking needs to be changed or checked with a second alignment?
Old 03-30-2015 | 03:24 PM
  #39
Tim08JK's Avatar
The first shop put a pry bar under each tire and showed up and down movement. At that time, I was under the impression that the ball joints were not supposed to have any up and down movement. However, after doing some research and reading the posts in the thread, I realized that a certain amount is acceptable.
I'm not sure what the second guy did, but he said that they looked good to him.
I originally went in to the first shop to have an alignment done, but they would not align it since they believed the ball joints needed replaced (it would need re-aligned afterwards, anyway).
Sorry for the confusion, I should have explained things a little better.
Old 03-30-2015 | 04:29 PM
  #40
Tim, you're on the money with that.. same thing here.. 3 shops and all said the same thing.. However one shop, I had to show them how to do the pry bar test.. all three shops gave the a passing grade.. But the new ball joints are on tap in a few months.
Quick Reply: Ball Joints bad after 1500 miles?!
