Ball Joint Recommendations
#21
I wonder why some people running 35's and going offroad have had good luck with stock while others have not? I have 38000 miles on mine (14 jkur) and still tight. Owner of the local offroad shop said stock ball joints won't last 15-20,000 miles. Seems stock are on average lasting as long or longer than the rest. Is it hype or is it just luck or what? If mine make it to 50,000 miles I will just replace them with stock. If they go out in the next few miles I will go with something different most likely. I like the sounds of the XRF ball joints tho.
#23
#24
#25
I got 120k on my stocks with most of it being 10" wheels and 2" of backspacing (most of the wheel outside and away from the hub). Who knows what makes some sets last longer but given what I was running, they should have been toast in 30k miles.
#26
#27
Synergy does an angled lower greased nipple so you can get it. The alloys in my TJ Rubi have a flush mount nipple that requires a special tool to grease them.
Any of these designs it's possible to remove the nipple and put a plug in there except when you're greasing them. I have no interference with my fittings so I leave them in stuff all times.
#28
Don't waste the time on ProSteer ball joints. They wear out and will take more labor to rebuild than replace.
I know this because I HAD them and replaced with Synergys.
#29
I do not have pics but the zerks do not interfere with anything. The steering was tight but loosed up some after about 2000 miles. Yes it drove drastically different. Did not know I needed ball joints until a buddy told me I did because of the irregular wear on the outside of my front tires.
#30
I was talking with a buddy the other day that was set on getting Dynatrac ball joints. If the XRF ball joints wear out after 50,000 miles, I will replace with the same because I will still be under the original price for the Dynatracs, besides the rebuild kit for the Dynatrac is more than the price of the XRF.
