Balancing beads
Balancing beads
Some do airsoft, some counteract beads, Some dynabeads?
I'm in the Midwest and finding someone to balance my 37mtr's on beadlocks is challenging.
I'm thinking beads is my best solution. This is my daily driver so I need to resolve this balancing issue in the next 1-2 days. I like the dynabeads based on what I've read.
Question is why is one better than the other? I've read lots of success stories for all sorts of beads. What are the negatives of these different bead options? Please use your own Experiance or a personally known Experiance.
Northridge 4x4
Northridge 4x4
I ran the dynabeads on my 35" nitto's and aev beadlocks for a couple years with no issues. I ran them for the same reason your looking at them, I couldn't find anyone to mount and balance my wheels and tires. The biggest issue I had was when I swapped to 37's they make a huge mess, we still find those beads all over my buddies garage lol.
When you say you are having trouble finding someone to balance your MTR's, do you mean you have had them balanced with poor results or do you mean that you can't find a place willing to try to balance them?
I ask because having owned a set of MTR's I'll never buy another they are frequently out of round and notoriously tough to balance. So if the places you tried can't get them balanced well it might just be bad tires...
If you have already mounted your tires, from my understanding is you have done one at least, then you're going to have to break the bead to get them in there. Dynabeads can be put through the valve stem if you are not running TPMS valve stems. Plus they also have an option for the larger beads for the bigger mud tires on their site that will not be able to fit through the valve stems.
I have ran them on my Harley and can't really say I noticed anything different. If you put them in through the valve stem it is a little bit of a pain in the butt. You should run a specialized valve stem if you are running them, if not they can get caught and not seal properly. I am sure their site sells this stem. It is recommended when putting air in the you have the tire rotated so the stem is up so all the beads are in the bottom of the tire and not apt to get into the stem. As for making a mess, I have never had any issue you just have to be careful when un-mounting and empty them into a garbage sack. They can be poured back in and reused.
Later
KingCon
Later
KingCon
When you say you are having trouble finding someone to balance your MTR's, do you mean you have had them balanced with poor results or do you mean that you can't find a place willing to try to balance them? I ask because having owned a set of MTR's I'll never buy another they are frequently out of round and notoriously tough to balance. So if the places you tried can't get them balanced well it might just be bad tires...
Northridge 4x4
Northridge 4x4
I have heard of these things for years but it still eludes me as to how they work?
Oh wow, just watched a YouTube video. Really cool stuff
I put 20k and they were just ok. Developed a shimmy and had to remove them. Give it a shot
You can always install some monster valves. Should be able to get air soft through them
