Balancing 35x12.5x17 tires
So my tires have a little vibration when i put them on this year. I noticed some of the stick on weights missing. I was told by one shop to change from the weights and go to a bag solution. Seems you toss in this bag and then it balances the tire during rotation. I have read about the beads for balancing and even some of the balancing liquids. I am not too fond of a liquid solution here in the north. Even though I do not these tires during the winter.
Okay - has anyone used this bag solution and can you share some information on it?
Thank you for your input.
Mandor6863
Mandor6863
I have the exact same sized tires on my jeep. Mickey Thompson side biters ATZ's. I have vibration only @ 60 MPH + that is noticeable everything below that is not there or so slight I can't notice it. The balancing strat used for my Jeep was the weighted bags not the stickers. I am not 100% sure if the bags are many small bags or just loose beads inside. I was not there for when they mounted the tires onto the rims. I will say this sometimes the vibration is less at the same speeds than other times. I have to guess that somtimes they stay as a lump or not spread-out as well as they should. I was told to avoid the "weight" stickers at all costs because as tires wear down they no longer keep them in balance because of unequal tire wear from driving, turning, and offroading.
I hope that helps you some.
http://www.youtube.com/watch?v=eq263AYgyYg
Just talked to a truck company and they are suggesting using centrimatics. Seems they are a ring bolts inside the wheel and they will balance the wheel. Not cheap but they said this is better than the bags. Here we go - anyone use the centrimatics?
Thank you all.
Mandor6863
Thank you all.
Mandor6863
Thank you all.
Mandor6863
Thank you all.
Mandor6863
After looking at the web site , you are correct. For Jeeps all I see is 5x4.5.
Back to square one. I will call around some more in the local area and see what options I have.
Thank you
Mandor6863
Thank you
Mandor6863
