bad U joint?
So recently i have notice when turning left at speed their is a pop in what seams to be the front end. Im no expert but im thinking this is either the U joint or ball joint. I had recently taken the coils out to put in new bumpstops. did give some beating on the axels to fit then springs back in. But i think this is unrelated. Any help?
Have someone turn the wheel when you're looking at the front end and you'll be able to track down the pop. I just had this issue with the axle side track bar bushing being shot.
Did the whole steering thing no result checked the u joint fine track bar fine. Finally look at the spring and its out if the groove. Felt pretty stupid
