backspacing for 40x13.50
You've got other places to look out for when you go to 40's. IIRC the rear of the wheelwell up front needs to be addressed and maybe trim the grill.
Sent from my DROID4 using Tapatalk 4 Beta
I currently has 3.5 BS and am fine. I trimmed up my end links to help though but with your BS you should be fine
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
to maintaing full steering up front without rubbing you need to net out to 1.75" bs on the factory axle at 4" of lift. More lift will allow you to run more bs at the wheels. I would suggest some flat fenders as well. Stretching the front will allow you more room for steering as well.
