Backspace help!!
Backspace help!!
I found a set of 5 20x9 wheels with 35" Toyo MT tires for a crazy good deal. I confirmed that these came off a JK, but the back spacing is +20mm. Will this work? I'm doing a 2.5" teraflex BB. Please help!!
https://www.jk-forum.com/forums/show...do-they-relate
Should be a 5.50" backspace. Stock is 6.25". With a 35x12.50, I would expect to rub when turning. (most lift mfg's suggest no more than a 4.50" BS for 35's). But, if you are buying from someone with a JK, why not just ask them?
If the tires are that good of a deal, buy them. Then find some cheap steelies with better backspacing, and just toss those wheels back on craigslist. Personally, I wouldn't buy wheels with the wrong bs and then buy spacers just so I could run them, but...
