Axle sleeves
Axle sleeves
What are the advantages of sealed axle sleeves and C2 gussets? And what kind of work goes into the install. I do alot of rock climbing and am trying to do anything I can to help myself.
They do exactly what you would think they do by thickening the tubes, and C's to help prevent bending. If you are around mud/water often I would recommend the seals for sure. I pulled about 1/4 cup of dirt out of my front axle cleaning up for the sleeves.
Of course I didn't get seals as I didn't know quite how bad they would be.
I had my front 44 beefed up with the synergy sleeve and gussets as well as some new alloy balljoints. After the fact i wished i would have bought some seals and put them in when the front axle was pulled out from under my rig. Do you have to remove the brake roters and everything to install the seals?
The synergy sleeves don't have the seal, but they don't have a lot of clearance either. If you spend much time with the axles under water you probably want to change the differential fluid.
I was guessing the seals he is asking about are the evo sleeves. They have an o-ring between the sleeve and axle.
