Axle off after lift
Old 10-09-2013, 01:37 PM
Rolltide66's Avatar
Default Axle off after lift
I'm sure there is a dozen threads on this, and I hope I don't get in trouble for starting another. After installing a teraflex 2.5 coil lift, bilstein and a 1" teraflex coil spacer on my JK, the front axle is off by 1". I'm just wondering how to re-center the axle. I do NOT have an adjustable track bar at this point. Can I do it without one? Thanks for any help, I truly appreciate it!
It's off on the drivers side.
Old 10-09-2013, 01:44 PM
nthinuf's Avatar
If you do not want to buy an adjustable trackbar, your other options are a relo bracket, getting rid of the lift, or leaving it alone. My opinion would be to get an adj.
Old 10-09-2013, 01:50 PM
Rolltide66's Avatar
That's what I figured. I'm not getting rid of the lift!
Old 10-09-2013, 01:52 PM
echoshotz's Avatar
I'd recommend just getting the Adj. Trackbar.
Old 10-09-2013, 01:55 PM
Rolltide66's Avatar
I know there are several out there. Any recommendations? One that won't break the bank, or get me divorced?? Lol
Old 10-09-2013, 01:58 PM
shabbernigdo's Avatar
Well you alredy sprung for the tera lift mite as well get the tera trackbar too.
Old 10-09-2013, 02:06 PM
Rolltide66's Avatar
Should I get an alignment prior to the track bar install? I don't drive it much, but it will take me a couple if weeks to get one. I have abs and esp lights on after driving on the interstate the other day.
Old 10-09-2013, 02:08 PM
jtphoto JK's Avatar
I drove around for a couple of years with the front diff being off center. As long as it handles OK and stays straight you will be fine until you get the Trackbar you want.
Old 10-09-2013, 02:12 PM
Sponsoring Manufacturer
TeraFlex's Avatar
Unless you have adjustable control arms, there is no point of having a alignment done. However make sure that you steering wheel is straight.
Old 10-09-2013, 02:13 PM
jtphoto JK's Avatar
Don't get an alignment till you finished installing parts.
As for the ABS/ESP lights. You need to recenter your steering wheel.
Quick Reply: Axle off after lift
