Axle gear question.
Axle gear question.
I'm planing to put the 4.56 gear from "Superior Gear" my question is: Do I have to change rear & front gears? if yes, do they have to be in the same ratio?
I'm sorry if this is a stupid question, but I'm no expert in mechanical stuff.
NO!!!!!!!!!!!!!!!!
You MUST do both at the same time unless you take out your front drive shaft. The front still turns in 2 wheel drive.
They have to be the same, or you will destroy your trasfer case in a matter of minutes.
btw the 4.56s havent been released yet. so far as i can get from vendors, no ETA yet either. so looks like you've got lots of months to save up. they did the write up on them in sept 2007 using Woods jeep. almost a year later & still no word on when (IF) the 4.56s will be released.
Read the first quote, then your answer. Please explain how this "will destroy your trasfer case in a matter of minutes".
