axle advice HELP!!!
Old 04-11-2013 | 07:47 PM
  #21
TheDirtman's Avatar
A front 60 with arb you are looking right around $9000 unless you get the optional ball joints and hubs. Add about $1000 more for those.
Old 04-11-2013 | 10:23 PM
  #22
big dr's Avatar
Originally Posted by BigSteve
I'm not trying to be a downer but what/where exactly are you wheeling that you feel like you need 60's and coilovers? Don't get me wrong it's a sweet set-up but it feels like overkill unless you are really wheeling some big rocks on the regular. I mean I just got back from Moab and my RK 3.5 Max Travel kit on 37's worked just fine. Just curious as to where your build is going.
It was either Samuel Colt or John Browning who said, " Build it as strong as you think it needs to be, then double it!"
Old 04-12-2013 | 02:49 AM
  #23
hollowpoint515's Avatar
Ya I spoke with a dynatrac rep yesterday and got some price quotes doing the front axle and a gear swap in the rear and beefing it up a little is what's going to have to happen
Old 04-15-2013 | 05:30 AM
  #24
I'm starting to consider going with teraflex's tr44 to replace my dayna30 front axle what all would I need to get ring and pinion
axle shafts
Locker
and would I be able to use anything off the dayna30 like the break assembly
Old 04-15-2013 | 06:27 AM
  #25
TheDirtman's Avatar
You should be able to reuse from the ball joints out, brakes, unit bearing, outer knuckles, stub shaft. Need new inner shafts or just get a 35 spline up grade and use the arb locker.
Old 04-15-2013 | 06:31 AM
  #26
I plan on getting it with an arb locker, new axle shafts, and the teraflex big brake kit other than that everything else from the stock30 will be able to be reused
Old 04-15-2013 | 06:35 AM
  #27
TheDirtman's Avatar
If you are doing all that the only thing left will be a the outer knuckles and unit bearing. Might as well throw some reid knuckles on there too, as well as new ball joints.
