Avenger, Hesco or Ripp???
Gearing is 4.10, but I am also on 36" tires so might be time for 5.13.
Supercharge over Turbo for that reason exactly - spool up. Wish I could afford a Hemi.
traction control off. I was in 4Lo.
Ripp!!!!
I have the Ripp and love it. The jeep feels like it has a larger displacement engine now. It is much more enjoyable to drive now and does great pulling up long inclines, when it used to bog down. Can't comment on any others out there, but I did my research and decided to go with Ripp after meeting Ross. He is a perfectionist when it comes to his products and that is a great quality to have when dealing with expensive motors. I went to his shop and he even showed me their test mule motor that they took apart after 30,000 miles. The motor looked great and I didn't see any major wear on any of the components. All I can say is that I am VERY happy with my decision.
The Roots type you do have power starting at Idle and increasing all the way to redline.
I think the main reason for any SC over a TC is heat. I have a Turbo on my DD and I can tell you that my underhood temps are considerably higher then stock, and I even have 3 giant holes cut in my hood. I've wrapped all the pipes with header wrap to try and get the temps down but it's a constant battle.
SCers only increase the intake temps due to compression so the under hood temps should not increase by much which is better for slow offroad use. Depending on the SC you also don't have to mess with your oiling system which can be another pain in the butt.
3rdly since we have a V6 it makes the piping for a TC more complicated, you could do a twin Turbo setup but that's a very expensive route and more complicated in it's own way.
Sponsoring Manufacturer
The centrifugal has similar charactoristics as a Turbo, where it has to "spool up". Not exactly the same but you don't have added power at Idle.
The Centrifugal (RIPP choice of superchargers) is the happy median – at lower RPM we take advantage of the air volume making your JK more fuel efficient, from 2500rpm and up the volumetric efficiency of both the engine and blower cross and boost just sails on in and off you go.
Lastly in our opinion and in the opinion of many of our users, because centrifugal superchargers are so linear in there boost delivery they are really easy to modulate both on and off road – whereas the power is very easy to find and make use off with no surprises like from a turbo or that "rubber band" type power you get from a roots style. That’s not to say that our system is for everyone, it’s just an all around solid kit that’s easy own right out of the box.
Question welcome,
RIPPTECH
Future RIPPer...
I have owned 3 cent chargers and 2 roots chargers and have to say for the 3.8 I am going to go with the RIPP charger once the wallet will allow. The install on cent chargers is a lot easier and straight forward and on smaller engines designed for higher rpm running they make a BIG difference( IMO )
Chad
Chad
