Atx slab question
Old 05-19-2015, 02:15 PM
jasenri13's Avatar
Default Atx slab question
My slabs have a batch of bad bolts for the beadlock rings. They rusted quickly. I have the new bolts. My question is would it be ok to change one bolt at a time without letting the air out or can I just go bolt by bolt on my jeep?
Old 05-19-2015, 02:49 PM
Rob 12B1P's Avatar
I dont know if it would hurt anything but I would probably let the air out just to make sure. Not like it would take much longer.
Old 05-21-2015, 10:59 AM
Former Vendor
TOTL Innovations's Avatar
You can do one bolt at a time.
I did that on my Walkers because I forgot anti seize during the install.
Old 05-21-2015, 11:29 AM
JE8154's Avatar
Let the air out. Go one bolt at a time then retorque the whole ring.
Old 05-21-2015, 02:49 PM
DJ1
Former Member
DJ1's Avatar
You can do 1 bolt at a time while it's still aired up and mounted. I've done it both to my 32 bolt Monster Beadlocks and to my 24 bolt TrailReady's.
If you're on the trail and happen to shear a bolt and need to put a new one it, it would absolutely suck to have to unmount the wheel/tire and air down then install the replacement bolt.
I've had 4 bolts shear before at one time on the Monster's and it still held air. Then again that's where having more bolts to hold the ring on has it's advantage.
I know the Slabs have less bolts than the Monsters. I think it might be the same count for the TrailReady's
Old 07-25-2015, 07:27 PM
Matthewd5's Avatar
im looking real hard at upgrading to the slabs, any other rim I should be looking at in comparison?
matthew
Old 07-26-2015, 04:29 AM
JE8154's Avatar
matthew
That depends... do you ever post on wayalife?
Old 07-26-2015, 07:22 AM
Matthewd5's Avatar
I love over the site but I am more of a lurker
so if the slabs weigh 67 pounds and my 37's weigh 86 pounds
I've got to see how much my pro comp steel rims weigh, pro comp 98's
matthew
Old 07-26-2015, 07:34 AM
JE8154's Avatar
matthew
Probably about 30 lbs per wheel for the procomps. I highly doubt that a slab weighs 67lbs, where did you hear they are that heavy?
Old 07-26-2015, 07:50 AM
Matthewd5's Avatar
I believe it was a thread on here
Quick Reply: Atx slab question
