Atturo Trail Blade M/T
Old 10-13-2015, 02:14 PM
  #21
Wildschwein's Avatar
What's your psi? It looks like you're on track to burn through the centers quickly.
It's funny that you mention that. I just noticed it when I posted that picture as well. I'll be looking into that on my way home from work today.
Old 10-14-2015, 08:24 AM
  #22
Alright, so cold (despite what tpms was saying) I was running 28-30 in the front and 24-26 in the rear. I chalked all four before my commute today and took another measurement warm. The fronts popped up to 32-33 and rears up to 28. Based off the chalk markings I lowered the pressure in all so the fronts were 30 warm and the rears at 26. We'll see what that does on the way home and then I'll re-chalk again to be sure. Sent from my iPhone using JK-Forum
Old 10-15-2015, 07:32 AM
  #23
Chalked tires again today, now I'm down to 28 in the front and 25 in the rear. My contact patch is getting a little wider, but still not all the way to the outside of the tread.
What pressure is everyone else running?
Old 10-15-2015, 08:35 AM
  #24
Flex_Junkie's Avatar
I'm running 37 in mine just because I don't want to stare at the tpms light. But it is riding on the center. I'm also running stock wheels so that doesn't help any.
Old 10-15-2015, 08:42 AM
  #25
Wow, that's up there. Have you considered reprogramming your TPMS to a lower threshold?
Old 10-28-2015, 01:29 PM
  #26
Ok, I think ice found the sweet spot which is 24-26 psi in my 2-door. Also, the tires performed great in the mud and on the rocks.
Old 10-28-2015, 01:52 PM
  #27
Good to know, I'm about to start dropping pressure in mine. Though running factory wheels on a 12.50 tire I doubt I'll ever get it to wear right. Lol
Old 11-22-2015, 11:27 AM
  #28
Took my trail blades out in the snow the other day and even crawled up some slick wet rocks. They did great! I was making it up the same paths the guys with dual lockers were hitting. I even maintained better traction than a couple of them. 35 X 12.5 r17, 16 psi Sent from my iPhone using JK-Forum
Quick Reply: Atturo Trail Blade M/T
