ATTENTION: Inspect Your Front Axle Housing!!
Old 10-24-2010, 08:44 PM
  #171
captjay's Avatar
Originally Posted by toddrussellcpa@hotmail.co
The front axle on my 08 JK just went out with 38,800 miles. I am running 33 x 13.5 x 18 and Chrysler denied the warranty because of the tire size.
your axle or the axle housing??
really anything besides stock, chrysler can do what they want. you have to remember they did go under so most liekly they will deny any claim that has an aftermarket part. yes we have the mos something act, but so many dealers and warranty companies are denying anything these days. penny pinching.
Old 10-24-2010, 09:46 PM
  #172
XHotrodX's Avatar
Default bummer
as always thanks for the input another thing to put on my weekly inspection checks.. you stated that all different wheel and axle combinations were experiencing the same type of cracks or breaks what about specific years do we have any years that seem to be having more problems than the others.....
Old 10-24-2010, 10:23 PM
  #173
StrokeHerAce's Avatar
Originally Posted by ElyasWolff
The welding should not do that much to the metal. Depending on what wire and process they used, the worst I can see happening is cracking near the weld. Shit this aint chromoly where you need to normalize the whole part in an oven. My guess would be too thin of steel, or the wrong alloy.
(rant) everything is recycled these days, and unless it is virgin steel you cant be sure it is the "true" alloy. I have see A36 that was tested, and had a small section of the larger plate that was very hard and had too much carbon it in!
I am thinking of welding on a brace and not putting in a sleeve. That way if your axle is bent you can weld it on and stop any further stress from the outside.
Key word is RECYCLED, those front ends are made from used TOYOTA parts.
Old 04-06-2011, 02:54 AM
  #174
Al Kurby's Avatar
Unhappy
I know this is an old thread, but the problem persists.
I just bent my D30 front axle housing, this is the 3rd time it happens to me. The gears on the ring and pinion are broken too.
We do serious off-roading, climbing high dunes and practically flying to get to the next summit..
Time to sleeve I guess. I run 33" Mickey Thompsons M/T's with 4:56 ratio, 2.5" lift, and 9.5t Warn Winch installed inside the front Mopar Offroad bumper.
Old 04-06-2011, 03:35 AM
  #175
Joisey's Avatar
you may want to look into a pro rock 44
Old 04-06-2011, 07:13 AM
  #176
Sponsoring Manufacturer
Dynatrac's Avatar
Sleeving isn't going to be enough. Where the tubes meet the housing will still bend. A better bet would be a truss. But, as was previously mentioned, a ProRock 44 would be even better as it will be stronger yet.
Old 04-06-2011, 11:07 AM
  #177
Al Kurby's Avatar
Thank you Joisey, Dynatrac. I am definitely going for ProRock 44.
I plan to re-gear.....Richmond 4:88, replace the drive shafts with heavy duty and I guess I will be good...am I on the right track here
Old 06-28-2011, 02:28 PM
  #178
Lilahs Jeep's Avatar
Default Broke Front Axle Housing
I just broke my front axle housing. When it broke I was on a mountain trail, nothing extreem at all. I went over a bump and heard a big snap! I got out and looked and the trip came to a complete stop. Jeep is currently at jeep awaiting to see if warranty is going to cover it.
ID:	176539   Click image for larger version
Old 06-28-2011, 02:57 PM
  #179
EVO MFG Representative
Andrew@EVOMFG's Avatar
Bummer. Hope everyone was ok...
JK looks fairly stock, Hopefully the dealer will take care of it for you.
Old 06-28-2011, 03:03 PM
  #180
nthinuf's Avatar
When you get a chance, could you clean up the break area a bit and snap some closer pics?
And good luck with the dealership! Hope they cover it, but if not, congrats on your shiny new PR44 or D60.
Quick Reply: ATTENTION: Inspect Your Front Axle Housing!!
