Atlas II ordered!!
#21
#22
I know of only two people that put an Atlas transfer case in a JK. They both had serious problems getting the electronics to work right. It was something about the JK computer not recognizing the new gear ratio, and either shutting things down, or going into limp mode. I think they both got it sorted out, but it was a major pain in the ass. So let us know how that goes, ok.
#23
I spoke with an Atlas rep at the Pomona auto show back in,,,, October was it?,,, he said they had finally worked out all the bugs and it was pretty much plug and play. Of course,, he is supposed to say that,, but I will continue to be optimistic. He also said it was about $3800 installed,, sooo,, saving my pennies
#24
That sounds about right for an installed price. Of course that doesn't include the 2 new 1350 Tom Woods drive shafts I need as well. Its a pricey addition for sure but I don't have any buyer's remorse at all!!
#26
Hello
i just did an overhaul where I replaced almost everything after the transfer case, so I guess my weakest point is the transfer case...
what are the main benefits of swapping out the factory transfer case?
i regeard to 5.13 and my factory transfer case is geared at 2. Something, it was really hard to read the stamped number on the factory case...
matthew
matthew
#27
Its a 2 speed 4.3. So far I'm told that the trickiest part of the install is getting the cable shifters in the stock location! There isn't a lot of room to play with.
#28
Hello i just did an overhaul where I replaced almost everything after the transfer case, so I guess my weakest point is the transfer case... what are the main benefits of swapping out the factory transfer case? i regeard to 5.13 and my factory transfer case is geared at 2. Something, it was really hard to read the stamped number on the factory case... matthew
I'm familiar with your build. Your ideal option is swapping in a Rubicon case. Direct swap, 4:1 crawl ratio, and you can pick one up for $500 plus your case in trade. The Rubi cases are rated for a ton of torque.
#29
Hello
what are the main benefits of swapping out the factory transfer. ase?
matthew
matthew
#30
