Atlas 2 vs Re-gear
I don't get how it would be messed up with the 1:1... if its fine in 1:1 I doubt many people care if the speedo is off while they are crawling in 5:1
Steve at Advanced adapters said using the atlas and 35" tires would not allow the speedo to be recalibrated I do not remember why but it was when normal driving. You could contact advanced adapters for more info.
I am not really in the market for a new transfer case so I wont be calling.. its just mechanically speaking, there is no reason it should throw off the speedo when it is in 1:1... It is essentially just passing the rotation out from the transmission to the rear driveshaft.
Speed is measured from the sensors at the axle ends not the TC. you can change gears and it does'nt make any differance. the only thing that affects it is tire size.
I am only passing on what Steve at advanced adapters told me. They make the atlas, they run the atlas on their 2012 wrangler and he told me that the one issue they had was when you use it you can not recalibrate the speedo. I doubt he would make it up as it is his business to sell Atlas'.
The speedo can be addressed with a programmer. .
It would seem so but Steve said for some reason you could not use the procal to fix the issue and it was regular driving that the speedo was screwed up. He said you just had to be aware the speed was going to be off and could not be recalibrated using a procal or similar device (I asked about the procal because I have one). He said other then that it worked very well with 35"tires.
