Artic Armor Kit Help
I'm thinking about purchasing this Artic Armor Kit straight from their website.
1.Is it as easy as it seems to weld to the axle?
2.Is it worth it?
3.Do I need to buy anything else with it?
4.Raised or Factory Tracbar height with kit?
5. Any other suggestions? :-)
I have an 07' Wrangler Unlimited X with RC 4" X-Lift on 34" Tires. Thanks for any help!
2.Is it worth it?
If you're looking at the Artec kit then you should look at the Barnes 4wd kit as well. Welding isn't terrible if you're properly equipped. What's your plan for welding to the cast center section?
I'm not welding it, my dad is coming to the house to do it. So idk. What do you recommend?
