Artec truss install
Artec truss install
Just wondering if anyone had any tips for my truss and gusset install. I'll be stick welding it using my miller cst 280. The only mig welder I have is a 110v Flux core that's why I'm going to stick weld it. Just looking for tips on what amperage is best to use and etc. Any help is greatly appreciated.
As much heat as possible and burn it all in at once without stopping. Joking
Around 180 amps. It's 1/4" to 1/4". 1" stitch welds, moving around the axle so you don't build heat up. If you don't have a Jig for the axle, take your time. I spent 8 hours welding a truss on my D60. Burn a little in, wrap in a welding blanket and go back in 30 min. Too fast, and you will give the axle a smile.
Also, there is no need to weld every inch. The more you weld, the more risk you take in warping. Careful with the heat around the diff or you can ruin the seals. And if you weld to the diff, be sure to properly pre and post heat and not to over heat. Cast can crack with too much heat.
