ARB Solenoid Wiring to SPOD
You don't need the sPod wiring harness unless you have ARB lockers. It's pretty easy and the instructions from sPod explains all you need to know
The 2 switch wires (black I believe) go to the SPod and the power wires (much larger diameter cable) go to battery. Do NOT run the power wires to the sPod. SPod only controls the ON/OFF switch cables. They might be purple now that I'm thinking about it. It's been a while so I can't filling remember the colors of cables.
He has the ARB Wiring harness already shown in that video I posted. So all he needs to do is connect the harness that came with the ARB compressor to the solenoids, they already have the wires attached to the plastic connectors. Plug and Play
Hopefully this helps OP a little better along with the video.
![](http://i34.photobucket.com/albums/d105/mhockey9090/Jeep%202013%20wrangler/D86E08AB-4B63-48F5-9E9A-E94D1F724BFC_zps4y5fhaws.jpg)
Many thanks, that was helpful! I located the harness to the solenoid and got everything wired up and working.
I am running the Viair Tank using the Synergy mount between the engine and frame, with the ARB Twin Mounted under the passenger seat... So the wiring harness for the solenoid was about a foot from the compressor. I had to cut the harness off splice in wire and run the wire to solenoids.
I originally set the compressor and tank up 2 years ago, so it was difficult to remember details on the harness.
