ARB part #???
Old 05-15-2007 | 06:12 PM
2K1TJ's Avatar
Default ARB part #???
I'm thinking about putting an ARB in the D44 when I regear. From what I've read, the correct part # is RD117, which is for below 3.92 ratio (pretty sure). From shopping around, I've seen another part # for the D44 for that ratio range (RD07). Is the RD07 an updated version or what?
Anybody know what the deal is? I'll e-mail ARB before I order of course, just though somebody here might know the scoop.
Old 05-15-2007 | 06:26 PM
MBAR741028's Avatar
I just had them installed in my front 30 and rear 44 the 44's part # is rd117. The part # from quadratec where I got mine is :
16100 203 ARB LOCKER 70-75&86&TJ DANA44 3.73&DOWN RD117
Old 05-15-2007 | 06:29 PM
jeepn0811's Avatar
Where did you mount the switches?
Old 05-15-2007 | 06:45 PM
MBAR741028's Avatar
Cooltec's switch panel.
Old 05-15-2007 | 06:53 PM
jeepn0811's Avatar
Nice setup. Are they easy to use there? That is about the only place I have found to mount any type of switch.
Old 05-15-2007 | 06:59 PM
MBAR741028's Avatar
yeah no problems. Below is a pic of where the air compressor is mounted under the hood.
Old 05-15-2007 | 07:12 PM
jeepn0811's Avatar
Did you use the factory front axle? Is it still a 27 spline inner shaft, or did you upgrade to a 30 spline. Superior IM'd me and said they were working on a 30 spline chromo axle for the dana 30, though I'm not sure of the factory spline count.
Old 05-15-2007 | 07:18 PM
MBAR741028's Avatar
I used the factory axles. There are no aftermarket axles available. Sucks because I will have to have them taken apart again when they are available
to upgrade $$$. Would have cost almost nothing except the axles themselves to do it when I had the lockers and gears done.
