Arb locker question
I was inspired by STUPIDFACE's handiwork so I went and did the same thing -- STUPIDFACE, you should make a "write-up" thread for this since it's an easy/cheap alternative to the $70+ off-the-shelf option. Wired/plumbed mine and it all works. It does vibrate the brake assembly (and pedal) when the compressor runs, but I don't think it's harmful. (pls. forgive the dirty engine bay...)
as for the write up, there isnt much to write about as for as the bracket goes. i mean, it aint hard to figure out where i got the idea. i dont have a problem paying the $70, but i had my compressor coming in the next day and wanted a bracket "now." instead of ordering the bracket and having to wait 3 or 4 days for it to come in, i went in the shop and made me one in less than an hour. i basically found a piece of scrap angle (4x4x1/4), measured the centers of the bolts that hold on the master cylinder, laid out the holes in the angle, cut it out using a chop saw and jig saw (out of tips for plasma). the next day when the compressor came in, i marked the holes using the compressor (didnt realize there was a backing plate that could have been used as a template). drilled the holes in the mounting platform then grinded and shined it up with a scotch brite on a 4" grinder. then last i sprayed some clear on it. unfortunately, i didnt take any pics while i was building it. i never thought that it would warant i write up....actually a write up never crossed my mind
also, i just wired up the arb compressor and switches yesterday. im gonna leave the installation of the gears and lockers to the pros. as i said, im going to try to get it to the shop the monday after mardi gras. thats monday after next to all but the 3 other poeple on here from the new orleans area..... here are some pics:
corey d
I just meant pull it out of the thread called "ARB locker question" (which actually started out as a part number clarification... sorry for the massive hijack) and stick it in the "Write Ups" section. No worries though -- I think a search will turn up this thread for anyone interested. My process was nearly the same except my "shop" consisted of a couple of cinder blocks, a saber saw, and an angle grinder
i have a question, i have no room in my engine bay anymore for anything, does anyone know if i can put the air compressor for the arb air lockers in the trunk space? or does it have to be in the engine bay?
David
Hard to believe that you have no room in your engine bay... unless you have a diesel, in which case I hate you.
There are many other options and some good pics in this thread here:
https://www.jk-forum.com/forums/modified-jk-tech-2/board-air-mounts-where-81854/
