arb locker question
Old 04-19-2016 | 05:49 PM
Lodemite's Avatar
I was thinking about adding a air tank where my old exhaust sat and put a skid plate over it . I was seeing a few tank size options . Anyone know witch is a good fit? I was thinking 2.5 gal it looks long and skinny like it might fit good
Old 04-20-2016 | 08:59 AM
TweakJK's Avatar
Originally Posted by Lodemite
lockers donot engage. pump stays on constant. once i figure out witch line is witch ima trace them with pump on se where the hole is. i figured its from when the pump was on constant fron the cold ait smashing the line and turning it on. i dont know how long it was on for. . when i goto fix the line is there a way to use the arb pump to air up my tires also? the crap pump i got now takes 20 minuts a tire ><
hopefully i can figure out this leak tonight goin back upto rubicon tomarow for a week
thankyou all for the input . has helped alot.
answer these questions
when you turn on only the compressor, what happens?
when you have the compressor switch on, and you hit the locker switch, what happens?
its important because how I am perceiving the problem, the issue is before the solenoids.
If it is on constant without the lockers switches on, dont even bother following lines. Thats not where the problem lies.
Old 05-01-2016 | 01:09 AM
Lodemite's Avatar
Default Re question
Sorry it took so long. Just got home from icehouse was up there a while came home picked up a winch and led light and ran back up no locker no problem . Snow was sucky tho lol 3feet over night
when you turn on only the compressor, what happens? Compressor starts running and stays running
when you have the compressor switch on, and you hit the locker switch, what happens? Some air pressure comes out but not enough to engage. Pump stays running
Quick Reply: arb locker question
