ARB diff cover installation
Windrocker, did you paint your ARB covers?
Yes I did. I really wanted the diff to match argent paint I put on my OME shocks.
I just taped off the clear coated bare iron parts and then scuffed up the red powder coat with a scotch pad and some bits of steel wool and cue tips for the smaller areas like in between the letters. Put on 4 coats of Dupli-color engine enamel and 4 coats of clear. I was very pleased with the out come .
As for the levels, I will have to check my front diff again tomorrow, I might be remembering that wrong
Cool, thanks for the info, these covers look awesome, I'll be installing at least my rear cover this weekend. Anyone use 75-140 in both front and rear? I know that's what David at Northridge recommends so I'll probably be doing that.
My rear trackbar make contact at full stuff (also may be due to drop bracket for lift) and my front drag link hits the front at full left (I think I remembered that right) turn.
I think I might have overfilled my diff a little after spilling a bunch all over the basement floor, has anyone tried one of those pump things to fill the diff? Also, have people been using the recommended factory fill level mentioned above with their ARB covers with good results? I think I might have 2.5 to 2.75 qts in mine now.
This diff cover looks amazing, but it's hard to read the dip stick so I would just rather fill it with the same amount every time.
So it seems everyone I ask seems to think that the fluid level should be the same as what is in the owners manual or ~2.5 quarts in a D44. I guess I will just go by the owners manual even though it's a different cover.
Question for you Rubi owners that use ARB diff covers... I noticed that the elocker wiring was held in place with a bracket that was mounted via the top two bolts of the rear diff covers... but with the ARB cover, since the bolts are recessed you can't do that... where'd you relocate that bracket? I just temporarily zip tied it to the park break line (that was near).
