ARB compressor in 2015 JK glove box
Anyone see an issue with mounting an ARB single compressor in the dash in front on the HVAC recirculation vent? I'm in a 2015 JK and it will run 2 lockers up air up. I don't like the under seat mount because I've had the floors filled with water and couple times crossing streams and deep Georgia mudholes. I couldn't find searching where someone has tried a dash mount in a 2012+ JK.
Kind of slick but what about the underhood option? I can't tell from the pic so can't see the solenoids but I'm sure it'd be a PITA to run the lines and wiring. Especially if you get beefier braided locker lines.
It may take bending up some metal to make a bracket to get it to work, also it does get hot so you'll want to keep wires away.
I mounted my ARB compressor behind the passenger side taillight. Works awesome, out of the elements, and isn't as loud as being in the cab.
*Picture isn't mine, just pulled off Google for example
Wouldn't it be easier to mount the compressor in a more traditional spot and then run a remote air inlet? Maybe run the air inlet to the vehicle air intake box, snorkel, or thru the fire wall to the glove box?
I gave up on the dash idea a few hours ago. I would have to take too much of the dash apart to get it mounted or at least make a bracket. I decided to go with under the drivers seat. My plan is to mount it to the floor on a 3/8" thick rubber spacer. It still keeps it cool and away from the mud.
