appropriate tire pressure
(Weight of your vehicle x 35%)/max load weight of your tire at max psi = % of max load
% of max load x max psi at max weight load = appropriate psi for the weight of your rig
Here is an example:
My 2 door weighs about 4500 lbs with a soft top & no spare.
My load range D Xterrains have a max load of 3195 lbs at 50 psi.
(4500 x .35 = 1575) / 3195 = 49.3% of max load
49.3% x 50 psi = 25 psi for regular street driving
Then, if I am going to do extended freeway driving, I could increase psi by up to 5 psi to reduce any chance of overheating the tire if traveling in the summer at high temperatures.
Here is an example:
The only thing confusing though is why do higher rated tires require more pressure. Should it not be the opposite?
You are safer erring on the side of load capacity than ride quality.
