Anyone unhappy with FT 3" Economy LIFT
Not unhappy with the lift at all. I did learn that when you do any 3" lift you are going to change the caster of your front axle. That affects steering. You will want to add an adj front track bar and some adj control arms to get things handling the same as when you started.
I was told by dealer that one thing to watch for with a 3" lift is that yer rear trackbars??? ( i duno i just work here) need to be 12" long or you will get tire rub even with proper offset wheels or spacers etc.
I've no idea what I'm talking about tho so check all that yersleves please..
I just installed mine today. Rides great. It does wonder quite a bit though. I'm guessing that has to due with the caster being off? Also, I know the adjustable trac bar will be something I add when I have the cash, but I have no bumpsteer at all so what problems will be caused by having the trac bar relocation bracket on the Jeep? What should I buy first, adjustable trac bar, or adjustable control arms? Can only buy one now not both.
