Anyone see these new mirror relocation brackets?
I was wondering if anyone has seen or has these mirror relocation brackets:
http://www.quadratec.com/products/13125_102.htm
Do you think that passenger mirror location is actually usable???
I don't know about you, but I like my stock mirrors in the location they are when the doors are on. I would assume you are looking to relocate the mirrors when the doors are off. In that case I would recomend the following mirrors
http://www.quadratec.com/products/13023_300.htm
they install and unistall very easily. I have them and they are great.
I will have them soon
I bought these from Quadratec yesterday. They should come in on Tuesday the 26th. I will post pics of the install how they look. I like the look of the stock mirrors and have my doors off a lot so these should come in handy.
I GOT THEM, AND HATE THEM!!!! They are are from Rugged Ridge. I received them, and the directions were all wrong, and called back, was then sent "revised" directions. You can only see 2" of the passenger side mirror with the doors on. I think that there could be a better design. If you get them make sure you get the directions that have "REVISED" on them, otherwise you will strip the threads out of the bottom of your mirror. They changed what bolts go where, and don't follow the pictures, they are all wrong. Sorry just venting. Good Luck!
I tried to install my mirror movers today. The stock bolts that hold the mirror to the door absolutely do not fit into the block off plates that come with the mirror movers. I would have to REALLY force the bolts into the blockoff plate ( rethreading them to fit by force ). The bolts they give with the kit to attach the new mount to the Jeep windshield frame do not fit the blockoff plate either. I know they make/sell tons of these, am I the only one that got block off plates with a different thread?
I'm not the only one...
https://www.jk-forum.com/forums/modified-jk-tech-2/rugged-ridge-mirror-relocation-brackets-wtf-need-help-39129/
I think I remember someone posting that they went into a local auto parts store and bought a cheap set of mirrors and they threaded right into the existing holes on the windshield brackets
I tried a couple different ones and couldn't find one that works. Both had the same size threads but one wasn't long enough and the other didn't allow for enough adjustment to be usable.
