Anyone running poison spider diff cover stock trackbar
trackbars are the same. well depending on the lift the axle may be forward or back depending on exactly how it is setup. if there are adjustable control arms involved the axle can be moved slightly. it sounds like if there is rubbing it is very slight, so a slight change in axle position(1/4") would be enough to rub. remeber the frame side axle mount is on the drivers side closest to the diff cover and it is in a fixed position.
