Anyone running the AEV 2" spacer lift?
Old 12-28-2012, 05:39 PM
  #21
railamer's Avatar
Just installed mine, and i need a little help. When turning from lock to lock, there is a slight popping noise and feeling about 3/4 of the way to full lock. I get this sound going in either direction. Seems to happen more when I am sitting still and turning the wheel, did not notice it when I was moving and testing it in tight a circle.
Any ideas??????
Thanks
Old 01-01-2013, 10:23 AM
  #22
railamer's Avatar
Found the issue. the locking bot on the tie rod is hitting the lower corner of the swaybar link extension bracket on the driver's side. Will grind down the corner and see how this works. Would have preferred replacement links, rather than extension brackets (which is what i thought that this kit came with).
Quick Reply: Anyone running the AEV 2" spacer lift?
