is anyone running 35 in tires with 410 gears
I've found that 35" tires and 4.10 gears work fine (even hills are not that bad --> it's called down-shifting); I'm in a 6-speed, so that is probably the difference.
21mpg? HUH? With 35's???? I have 4.10's and 35's, I keep the overdrive off and run about 2800 rpms at 65mph by the speedo which is off. Overdrive on is gonna bog it to about 1800rpms. I get 13.5 to 14.5 city/ highway doesn't matter. You musta put one of those hydrogenfluxcapacitorthingamabobs on to be gettin 18 or 21mpg with 35's
I read your question again, also my truck did better with those gears and the same tires, I drive a jeep now. please call a jeep a jeep.
I ran 4.10s and 35's for about a year. Like others have said, turn the OD off every time you get in and especially on uphill grades. You'll put undo wear (and heat} on your transmission.
It really isn't that bad. I run 5.13's now!
Pay no attention to toad and her resetting her MPH!
