Anyone run this setup?
Old 12-02-2010, 09:47 AM
mkjeep's Avatar
Originally Posted by 4x4andFlyFish
I have about the same build. I have a '10 sport 2 door, 6 speed 18x9 wheels wrapped with 35-12.50 Nittos. 4" suspension lift and 4:88 gears with JKS discos. I added sleeves and C axle gussets to beef it up. sleeves and gussets are very inexpensive! I don't have lockers and wouldn't recommend lockers in your D30. Just do a better job finding the proper line to off-road your JK by trying to keep your wheels on the ground. Discos are a must for the D30 since the sport doesn't come with electronic disconnects.
Adding lockers to the D30 will cost around $1500-2000. Save that money for when the axle breaks and buy the D60 and put in the ARB air lockers. Hopefully the 30 never breaks and your good for ever.
A lockright for the d-30 is only $250-$300 and you can install it yourself.
Mine's been locked for almost 2 yrs. I've popped a couple dried out ass u-joint caps and replaced the joints, caught it before axle damage.
Old 12-02-2010, 01:53 PM
MikeW2002's Avatar
Thanks guys, yeah I guess I should have said that I am going with my original idea of getting a cheaper Sport and dropping a little $$ into the D30 (lunchbox locker, 4.88, housing strength) and run 35s for a while, then stepping into a HD44 or 60.
Old 12-02-2010, 06:32 PM
mkjeep's Avatar
You'll be ok, most of the naysayers on here have zero experience with it personally and are epitome of web-wheelin.
Old 12-02-2010, 06:58 PM
Battle Damage's Avatar
Lately these threads are more about whinny little b****s crying about who said what. This is a tech forum. For men (and women)that like Jeeps. For everyone else sorry about my outburst.
Old 12-03-2010, 04:28 AM
mkjeep's Avatar
Originally Posted by cbloyer81
Louisiana huh? There is a lot of hard core wheeling there
Depends on what YOUR definition of hardcore is I suppose.
Seems like your the one who's whining.
There is a way for you to avoid this awful situation. Log off.
As there is for you.
Old 12-03-2010, 04:30 AM
mkjeep's Avatar
Back on topic please.
Old 12-03-2010, 12:23 PM
nthinuf's Avatar
It's all about personal experience, personal opinion, and mechanical expertise.
My experience: I didn't trust my 30 with a locker, so opted for a TruTrac. During the install, we found that the tube was bent up about 3/4". This is from 98% on-road, 2% forest service roads. No crawling, no mud, no stupidity. (I know, it's a waste of a good vehicle. Someday I'll get the time to get out there more)
Rather than dump $1000+ on straightening and new gears, then more on beefing up a housing I already know is weak, I opted for a built 44.
It just depends on 'your' preference. MK knows his 30 is weak, he indicates that he has replaced 3 joints already, and says he carries spares for when it breaks again. He obviously has the mechanical expertise to make a 30 a viable offroad axle.
Personally, I opted for over-built rather than keep replacing and repairing...
Old 12-03-2010, 07:28 PM
eDiveBuddy's Avatar
I have a Locked D30 on 35's. It's holding up just fine. And that's with a V8. Tubes and C's have the EVO gussets and I braced the upper control arm mount. I am waiting to break it so I can get a ProRock 44 and get 37's. But until then I'll stick with the 35's.
Quick Reply: Anyone run this setup?
