Anyone run a double front track bar?
I was talking to a mechanic for Jeep the other day and he said he fixed a JK's death wobble by adding a second front track bar. Said he got longer bolts and had to grind down a bit near the "hump" and the problem was solved. He said he also put a heavy duty steering stabilizer from a Ram 3500 on it. Said the steering was nice and tight and didn't waiver a bit over a bump.
What do you all think?
DW is usually just caused by loose bolts. Check the Planman's check-list for all the info.
A new stabilizer just masks the problem till it gets worse.
Originally Posted by maine07jk
I dont disagree w/ anyone here. I'm just throwing out what I heard to see if anyone actually has done it.
Originally Posted by Battlefrog
I don't even know how you would run 2 trac bars? As for the SS, 99.9% of the time it has nothing to do with death wobble..
