Anyone recently install a rear SRC bumper and tire carrier?
Old 04-30-2016 | 04:12 PM
AHunter's Avatar
Originally Posted by GunDude
You should be able to loosen upper bolt on swing arm to move it down. I added a chain and retainer clip to keep my handle from coming up. I also added 2" receiver hitch above to put hitch basket when on trail.
Thanks for the pictures and info. Sweet idea with the 2" receiver above the tire.
I had a page in the instructions showing to install with it and then the very next page showed it being installed without it?? I couldn't get it to sit flat against the carrier without pushing the handle outwards.
Old 04-30-2016 | 04:42 PM
AHunter's Avatar
I was able to get that bracket on and adjust the swing arm to align and latch/close better. Thanks for the info and pics GunDude!
Old 05-02-2016 | 03:01 AM
AHunter's Avatar
Few photos of the finished product. I found the easiest way to get that bracket on was to put it on loose then close the swing arm into place and tighten it then. That bracket helps lock the arm, it goes into the latch when closed as you can see in photo #1.
ID:	645740   Click image for larger version
ID:	645741   Click image for larger version
Quick Reply: Anyone recently install a rear SRC bumper and tire carrier?
