Anyone Make Aluminum Skid Plates
yeah, Ok... I can't remember the technical name of the alloy... But it contains steel, aluminum, and chromium. I know folks in my team called it Chromoly, even though true chromoly is nothing more than steel/chromium alloy. In fact, anything with Chromium got that label. If you want me to be technical about it I can...
Chromium is stronger than steel but is very brittle... mixed with steel it provides excellent strength. But, the weight savings is minimal. Combine it will aluminum, you get a light alloy that is strong. Chromium bonds with both Steel and Aluminum so you don't have to worry about a galvanic reaction. Other materials that allow aluminum to play nice with steel include zinc and brass.
There are so many different alloys out there with the purpose of adding a traits to the material at and. Aluminum is very ductile. That is why electronic boards use them. If they could build those boards using copper, they would... but copper is not as ductile as aluminum and has a tendency to crack.
Yes aluminum is soft, but that is where chromium comes into play.
My point, is you could easily make an aluminum alloy skid plate that will works as well as mild steel and be lighter.
PCB (Printed Circuit Boards) us only Copper. It conducts much better than aluminum does. Although it is heavier, and cost more. But as far as flexibility, copper is softer than aluminum is. The only way copper will crack is if its very cold, or its thin, and is repeatidly flexed back and forth.
From what I have read, the cavemen actually used wood and bone for their skidplates, fastening them to their Jeeps with sinew and tanned leather. A Jeep with wooden skidplates - we've come a long way. LOL
Our wives and/or girlfriends think we spend enough on these Jeeps as it is. Can you imagine if we started hanging a bunch of titanium parts on them. For most uses good old steel does pretty damn good. Easy to repair and cheap. Aluminum has it's place but I see very little off it on the heavy duty equipment I work around (think 2300 HP engines, 15,000 to 20,000 psi pumps, 500 ton hoists, etc).
ok now that got off the floor........ i bet that 10 or so pounds will look REAL good atfter you punch through your alum. skid and right through your oil pan or tranny. But if it is what you wish. good luck
07 JK Unlimited
3 inch BDS suspension lift
33x11.5x16
JKS Quicker Disconnects
Warrior Products Tube Doors
Mopar Off Road Rear Bumper
Oil Pan Tranny Skid Plate by SkidRow.....STEEL
Custom Front Winch Bumper by RoundStar OffRoad
Skyjacker Adjustable Rear Track Bar
Skyjacker Brake Line Extenders
Rock Krawler Adjustable Front Lower Control Arms
Dual Steering Stabilizer from Rough country
And Plenty of "CHARACTER" From rocks and Trees
“A bad day wheeling, is better than good day in Prison!”
^ YCP 4X4 motto ^
Eternal ***erator
Well, i dont think it is all that far fetched, and i understand the reasoning. If you could make one as strong as the steel version, that wouldnt corrode sitting next to steel, i think it is actually a good idea, the weight savings and heat dissipation would be nice perks.
The aluminum one on my old motorcycle took an ass-stomping and though hammered, still worked just fine.
You said copper is more flexible... Its not.
And as for Chromoly which is what started this path. Chromoly stands for Chromium alloy. It has been associated with a specific combination of steel and chromium... but it still just means a chromium alloy.
