anyone have smittybilt GEAR console on 2010 jk?
like the title says im looking to buy the smittybilts GEAR console but read one post that sid it will not work on the 2010 due to somthing being diffrent?/ anyway is this true ??
Are you talking about the overhead GEAR console? On mine (a 2010) the center foot-loop insn't centered like previous models thus off setting the console frame. When you install, the console will not be centered and end up closer to the drivers side. I didn't like it being off-center so I modified the front bracket that came with the console to center it back up. I also didn't utilize the hose clamps that secure the rear, I used a couple self tapping screws into the flat area of the roll bar. I also have the hard top on with it, you'll have to ditch the front center lever that holds the hardtop on. I haven't noticed any ill effects from this, only just a slight whistle if the wind blows right due to the top not sitting as tight along the windshield frame. Over all it's a pretty sweet set up that adds much needed storage space to the JK.
