anyone with full traction issues
#31
i went and did some looking under the jeep to see what i was in for.
does the exaust come apart in sections or is it one big piece from engine to muffler.
and are there write ups out there on how to remove exaust and fuel tanks??
#32
One piece of advise is to use a spray something like PB blaster and hit the rubber mounts. It'll allow rubber to slide off the steal mounts easy.
the fuel tank, is just the couple bolts holding it on, you'll have to unclamp the fuel lines. Just squeeze on the colored part of the connection and they'll pop right off.
You also have to disconnect the electronic connection, but thats once the tank is down. Make sure the tanks low and use a floor jack under the skid. its easy to remove
#33
thank you all for this info, come spring ill show you how it worked out.
btw since there isnt a write up on this 4"/6" kit, should i take pics of the stages of assembly
#34
http://project-jk.com/wpg2?g2_itemId=105971
Hope they help
![Smile](https://www.jk-forum.com/forums/images/smilies/smile.png)
