anyone with full traction issues
#21
Just so you know, the track bars are not designed to have a zerk, if they make noise you need a thicker or tackier grease. No reason to add a zerk and work for yourself. I greased mine with a crappy grease from walmart. It lasted about a month. I then bought a little more expensive grease from napa. Never had to touch them since. It's been about a year
#22
js.
#23
Funny how your attitude changed about the lift since the PA show.
if you have spacers and do not have extended bump stops, you caused the coils to over compress and made them fail.
use some anti seize on the locknuts, if you didnt shame on you living in a Salt state. failure to greese will also ruin your bushings.
You cant blame the company for lack of maintance.
#24
well my kit just got here today. that was a little over a week of ordering them
now i gotta go thru it to make sure everything is here. and hopefully have the money for my other parts and install them all this spring/summer
#25
omg i was reading thru the install instructions and it says i have to remove the gas tank and exaust before even starting this kit.
i understand the gas tank but why the exaust
#26
Ah, you have the long arm, ignore most of the negative reviews, different bushings in the long arm.
The exhaust gets in the way of cutting and grinding the stock brackets off. I tried to work around it. It didn't work.
Removing the exhaust is easy, it's not really a big deal
#27
You'll be fine, 40,000 miles on the same set of coils and shocks with no sagging. I'm running 37's on the 3" coils. If it was sagging. I wouldnt be able to run the tires
Keep the lift greased and you'll be fine. They sold a ton of these kits when the JK came out. With sales like they had, you will find some people thats not happy. It can happen with any lift. hey, Atleast you bought a lift that was made in the USA
Not many can say that
they are still testing out different bushings for people that don't like to grease there lifts.(ie no maintance) I don't know a time frame of when the bushings will be available. They are a ton of happy customers with their products especially the guys running the long arm kit..
#28
I'm not saying that all of these kits will have problems, and you're right that the long arm seems to have fewer complaints, but I resent the implication that it was somehow our fault that the "ultimate" kits are not living up to their claims.
That said, this is a bit off topic since the OP picked up a long arm. Good luck with the install and the kit -- let us know how it holds up (be sure to post back positive feedback as well as negative, since it helps everyone to get good info out there both ways).
#29
#30
Seems like you have lucked out with your coils. Don't know why this varies so much, but a little searching will reveal that this is not an uncommon issue with these kits.
Sorry, I really have to chime in to say that it's not lack of maintenance or "cheaping out" on grease that has caused these failures. I greased my kit religiously with every tire rotation/oil change since new. Come to find out the way the bushings were designed, who knows whether the grease was reaching everywhere it needed to, but I would grease it until it squeezed out from around the bushing. What's more, I researched and found the highest quality, tacky, lithium grease that I could source. I tried some from Napa and some ordered direct from Amsoil.
I dont think I lucked out on coils, theres very few issues with coils, they do have two sets, HD and regular for guys running winch's. If they didnt ungrade they could very likely had the wrong ones.
Your right, way offtopic since the OP bought the long arm and they only have the rear uppers with the same bushing style.
