Anyone with a custom exhaust on a CRD JKU?
#21
Originally Posted by pmaia
Great job..
I have 2011 Rubicon CRD. It has particle filter and CAT. I would like to eliminate both, but keep without problems or error messages!! Is it possible?
#22
Thanks for answer..
Will try to see if there is any sensor...
My 2011 has 200 hp from factory.. But I think the particle filter is affecting the perfomance... Donīt know how they have those HP values!!
#23
Video of finished exhaust system.
The completed system is 3' dump pipe with no particle filter, running into to the standard 2.5 inch system to the rear where I have replaced it with a straight through 2.5" muffler with mandrel bends and a 3 inch tip.
http://youtu.be/1bbbmT2MKa4
#26
Sounds the goods Doneanddone.
Pmaia,
I'm keen to hear how you go eliminating the DPF, I've got a 2011 setup (DPF, sensors etc) and will require a custom exhuast due to the up and coming suspension work. Will most likely keep the DPF though for compliance reasons, while ditching the muffler unless drone becomes an issue.
Cheers,
B.
Pmaia,
Cheers,
B.
#27
By the way if the sensor is before the DPF then you should be fine removing it. If your in Australia there is no legislation then says you have to have one "technically" the guy that did mine was so confident I'd never get booked he swore he'd pay my fine if I got busted!!
